10-04-2018, 09:49:28
Halo
Let me introduce myself
I am beginner with Innogy SmartHome.
I would like to improve heating system in my house. am almost ready to use home made arduino system.
I just start use Innogy Smarth home system
I am out of my know-how how to create scenario
I would like to controll temperature in two bathrooms (1.04, 2.04)
Each bathroom is equipped with floor heating (1.04_floor, 2.04_floor) and also towel rail radiator (1.04_ladder, 2.04_ladder). Water from central boiler is used as heating medium
I would like to use floor heating for permanet keep temerature to 20°C. They are equipped with "mechanical" thermostatic heads now. Thermostatic heads are out of both bathrooms, each one in separate box.
Tower rail radiators will be used for temporrary increasing of temperature in defined time span
I would like to use also function "open window". for all 4 subsystems.
My hardware:
1. central unit (2 pcs)
2. electronic thermostatic heads v1 - 6 pcs
3. window open sensor - 1 pcs
4. in-wall switch - 1 pcs
5. remote controlled socket - 1 pcs
I do not have room thermostat and control unit for electrich heads for floor heating ventils
I would like to:
1. use electronic thermostatic head for each subsystem.
2. use electronic heads for ladders as remote temperature sensor for floor heating (1.04_leather for 1.04_floor, the same for 2.04)
3. use one window sensor for both bathrooms (windows are opened to ventilation position during summer)
4. time span and temperatures are identical for boths baths
Have You got any idea how should I create scenario? I was able only use one room with window sensor and all 4 thermostatic heads now
Is there any option od some another programming interface?
Thank You
Martin
My hardware:
I would like to:
Thank You
Martin
